I have set SpaceClaim to repairing these inexact edges in a complicated model, but it is taking hours. How can I get around this?
Tagged: ansys-spaceclaim, Geometry Repair, Inexact Edges
June 6, 2022 at 10:33 am
FAQParticipantQ: I have a geometry that I have imported into SpaceClaim. It is a very complicated model and SpacClaim is finding thousands of inexact edges. I have set SpaceClaim to repairing these inexact edges, but it is taking hours. How can I get around this?
A: It is often unnecessary to correct the inexact edges. Many geometries will still mesh perfectly without addressing the inexact edges. The recommendation is to ignore these and move on to meshing the geometry. It is very unusual for inexact edges to pose problems at the meshing stage. If you have a geometry with inexact edges that is causing problems during meshing, please share this with your suppot engineer.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- ANSYS SpaceClaim: Imprinting Geometry
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
