I have Microsoft Excel locally installed but I don’t see the Microsoft Office Excel tab available under Component systems in Workbench Window.
January 25, 2023 at 7:28 am
FAQParticipantPlease follow the steps below to identify what might be wrong: •Verify if the Excel folder exists in the installation directory at C:Program FilesANSYS Incv2xxAddinsMSExcel with all subfolders and dlls exists. •On the main workbench window please ensure that the Microsoft Office Excel icon is activated by going to View>Toolbox Customization and Please enable the visibility of Microsoft Office Excel Component by checking the box next to it. If any of the above is not as per expectation, reinstall Excel and it should work. If the problem still persists reinstalling Ansys might be helpful.
