Licensing
Licensing
I have just installed ANSYS Workbench 11 SP1 on a new Windows XP 64-bit platform. When I try to start Workbench by selecting Start > All Programs > ANSYS 11.0 > ANSYS Workbench I get a pop-up error: ========================= This application failed to start because MSVCR71.dll was not found. Re-installing the application may fix the problem. =========================
    • FAQFAQ
      Participant
      In a Command Prompt window change to the folder c:program filesansys incv110AISOLCommonFilesMiscAWPNC (or to your installation folder if you did not use the default) and issue the following two commands: DependencySetupx64.exe vcredist_x64.exe After this Workbench should start with no problems.
