I have installed the ANSYS Workbench 11 SP1 and the ANSYS CFX 11 SP1 software on my Windows XP 64-bit machine. When I try to open a file in CFX-Pre in ANSYS Workbench I get the following message: =================== CFX-Pre Start Failure CFX-Pre terminated while attempting to connect to Workbench. ==================== I installed the 32-bit versions of Workbench and CFX 11 SP1 because of CAD issues.
March 17, 2023 at 9:01 am
FAQParticipantOn a Windows 64-bit machine it is expected that the 64-bit versions of Workbench and CFX would be installed; the issue being seen is due to having installed the 32-bit versions. The workaround for this is to set the variable CFX_FORCE_WOW64 to the value 1. This has to be set as a regular environment variable (using Control Panel > System > Advanced tab > Environment Variables button > System Variables list > New) as its value needs to be known before perl is run at the launch of CFX.
