I have hooked the surface reaction UDF DEFINE_SR_RATE to a surface reaction in Fluent. When I run Fluent, the rate for that surface reaction is always zero, no matter what is specified in the UDF. The UDF is properly hooked. What could be wrong? Also, if both Arrehnius coefficients ( via GUI) and DEFINE_SR_RATE are specified for a surface reaction, which will take precedence?
Tagged: 17.2, fluent, fluid-dynamics, Species/Reactions, Surface Chemistry
June 5, 2023 at 7:06 am
FAQParticipantThe reaction is likely missing from the reaction mechanism. Surface reactions must be included in the reaction mechanism by editing the mechanism in the Mixture Template. There, make sure that the Reaction Type is set to “All” so that the surface reaction can be included in the mechanism. UDFs that are hooked and apply to a given surface reaction will take precedence over any coefficients that are defined in the GUI.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
