I have defined boi in scoped sizing. But I can not see refinement in boi. I see only some refinement at surface mesh.
Tagged: 19, FLUENT Meshing/Tgrid, fluid-dynamics, General, meshing, Size Functions
May 15, 2023 at 8:33 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: refinement, boi, sizing, tet meshing
1. 2055821.pdf
- Skewness in ANSYS Meshing
