General
General
I have created a monitor point for pressure in CFX-Pre at a certain location. In comparing the final monitor point pressure reported in the Solver Manager with results from a probe function at the same coordinates in CFD-Post, the values are slightly different
    • FAQFAQ
      Participant
      The monitor point values reported in the Solver Manager are calculated using the nearest vertex to the monitor point coordinates. In CFX-Post, the probe function uses a tri-linear interpolation to determine the value at a point based on the monitor point coordinates. The values returned in CFD-Post will therefore be more accurate than the solver monitor plot. Note that the finer the grid, the smaller the difference between the two results.
