I have compiled UDF using Visual Studio command prompt. I got ‘libudf’ folder. Now I open same Fluent case file in Workbench. How to access UDFs?
Tagged: 19, fluent, fluid-dynamics, General - FLUENT, udf, workbench
April 5, 2023 at 2:32 pm
FAQParticipantPlease copy ‘libudf’ to Workbench sub-directory named ‘Fluent’. e.g. D:UsersR19_filesdp0FLUFluent. After this, open Fluent from Workbench and use User Defined –> Functions –> Compiled –> Load.
- Skewness in ANSYS Meshing
