I have been working on a SpaceClaim geometry cleanup for hours and SpaceClaim crashed during one of the operations. Now I can’t open the file I was working on. How can I recover my model?
May 15, 2023 at 8:33 am
SolutionParticipantYou may not be able to recover the most recent version of the model, but you should be able to go back to a slightly older version by playing back one of the journal files from your previous SpaceClaim session Journals record the actions you performed while creating your design, including file actions, such as closing a design. You must play back a journal from a fresh SpaceClaim session to avoid errors. SpaceClaim records journal information automatically to SpaceClaim journal files, which can be found in one of the following directories: C:Users
AppDataRoamingSpaceClaimJournal Files on Vista systems C:Documents and Settings Application DataSpaceClaimJournal Files on XP systems The link below from the SpaceClaim Help documentation shows how to activate and use journalling in SpaceClaim: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/SpaceClaim/v192/en/Default.htm Attachments:
- Skewness in ANSYS Meshing
