I have an assembly with several components and would like to save each component as a separate STEP file in a specific directory using SpaceClaim.
June 6, 2022 at 10:33 am
FAQParticipantSelect all components in the structure tree, right click – Source – Convert to external. This will save every component as a separate SpaceClaim file in same folder where assembly file is saved. Next, batch converter can be used to convert a group of such files in one format to another. This converter is located in the install directory of SpaceClaim and called converter.exe.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
