I have a very large JT file and ICEM crashes while trying to import it. How can I find out what’s wrong?
Tagged: 18, CAD Interface, fluid-dynamics, General, icem-cfd
June 5, 2023 at 7:06 am
FAQParticipantSpaceClaim 18.0 will be able to open the file. Once the file is open, you can assess it, remove any unnecessary features and also break the model into sections. The sections will import into ICEM one at a time. Create several tetin files from the model and merge these together into a master file.
- Skewness in ANSYS Meshing
