I have a reaction that with rate that is a function of both products and reactants as follows: H2O => H2 + 0.5 O2 with r = k [H2O] [H2]^-0.7 [O2]^1.05, k – A exp(ER/T)T^n How can I enter this in CFX? CFX GUI only supports dependency on reactants.
- H2 + 0.5 O2 with r = k [H2O] [H2]^-0.7 [O2]^1.05, k – A exp(ER/T)T^n How can I enter this in CFX? CFX GUI only supports dependency on reactants." target="_blank" rel="nofollow" title="LinkedIn">
- H2 + 0.5 O2 with r = k [H2O] [H2]^-0.7 [O2]^1.05, k – A exp(ER/T)T^n How can I enter this in CFX? CFX GUI only supports dependency on reactants." target="_blank" rel="nofollow" title="whatsapp">
- H2 + 0.5 O2 with r = k [H2O] [H2]^-0.7 [O2]^1.05, k – A exp(ER/T)T^n How can I enter this in CFX? CFX GUI only supports dependency on reactants." target="_blank" rel="nofollow" title="reddit">
- H2 + 0.5 O2 with r = k [H2O] [H2]^-0.7 [O2]^1.05, k – A exp(ER/T)T^n How can I enter this in CFX? CFX GUI only supports dependency on reactants." target="_blank" rel="nofollow" title="facebook">
Tagged: 19.1, cfx, fluid-dynamics, Modeling/Setup Advice, reaction, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantThe reaction : H2O => H2 + 0.5 O2 will by default have forward reaction rate: r = k[H2O] and backward rate r = k[H2]^-0.7 [O2]^1.05, where k = A exp(E/RT) T^n The trick here is to set the forward preexponential factor equal to A *[H2]^-0.7 [O2]^1.05 This can be done with an expression containing the product molar concentrations as below: A= 1.38099E+19 [m^1.050 s^-1 mol^-0.350]*1[K^-n]*(H2.Molar Concentration)^-0.7*(O2.Molar Concentration)^1.05 The dependency of the rate on H2O will occur naturally as a result of CFX’s interpretation of forward rate.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
