I have a finite rate chemistry simulation with reacting particles surface reaction setup for a particle, but no matter what I do with the Arrhenius coefficients, the surface rate is always zero. How can I fix this?
Tagged: 18.2, BCs & Interfaces, fluent, fluid-dynamics, materials, Reacting Flow, Species/Reactions
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: chemistry, surface rate
1. 2051493.pdf
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
