I have a diameter of a hole as parameter. In some cases, hole is eliminated. But at this time, driving dimension also disappears. How to tackle such cases?
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: parameter, spaceclaim, design points
1. 2062368.pdf
- Skewness in ANSYS Meshing
