I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
May 25, 2023 at 7:29 am
FAQParticipantIf the contents of the aedb folder contain an auto-saved version (i.e. a bunch of files with a trailing ‘+’ character), you may be able to recover that by doing the following: 1) copy model_name.aedt to an adjacent file named model_name.aedt.auto 2) in the aedb folder, open the .config+ file and copy the LastUpdateTimeStamp id (i.e. LastUpdateTimeStamp=1491431289) 3) open the new model_name.aedt.auto file and replace the LastUpdateTimeStamp to match what was in the .config+ file. After this, when you open the aedt file, Desktop will prompt you about autosave. Choose the replace option.
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- How to Create Bondwires in 3D Layout ?
