I get this error when starting the solver: “error reported by io module: oicntc: offset array input is wrong.”
April 5, 2023 at 2:32 pm
FAQParticipantThis error message can be caused when the definition file written from CFX-Pre has encountered an error and did not complete correctly. Assuming your system is stable and has enough disk space, re-writing the definition file will solve this problem.
- Skewness in ANSYS Meshing
