I get this error message in Q3D: “Perfect conductor and non perfect conductor can not be in the same net! ‘part name 1’ is a perfect conductor while ‘part name 2’ is a non perfect conductor”. What is the reason?
September 22, 2023 at 11:02 am
SolutionParticipantPerfect conductor is an ideal material that doesn’t exist in the nature. If it is used on the same net in a Q3D model with non-perfect conductor (copper, gold, silver, …) it doesn’t allow the model simulation. Please exchange the PEC by a real material.
- EM FAQ: How to export the simulation results/plots of Maxwell?
- EM FAQ: How to quickly fix or heal imported geometry in Maxwell 2D?
- ANSYS Icepak: I get a meshing error – “Warning: no mesh exists for block, body”. How do I fix this?
- EM FAQ: How to define project variables that apply to all designs?
- What are the default boundary conditions in different solvers?
- EM_FAQ: When a DXF file is imported, how can you generate Areas from selected Lines?
- Vacuum Thermal Modeling in ANSYS Icepak
- ANSYS Icepak: How to delete unused materials in a project?
- ANSYS Icepak: O-grid meshing issues
- EM FAQ: How to link the mesh from a static solver to transient solver in Maxwell?
