April 5, 2023 at 2:33 pm
FAQParticipantThe click / drag setting on the left mouse button is not set to rotation by default. The default setting is, to use the selection of the graphics window transform button. The user can set this by menu > edit > preferences within the mouse & keyboard section. Make sure the Graphics Window Transform Button is set to rotation.
- Rocky GPU Buying Guide
- Skewness in ANSYS Meshing
