I cannot seem to find the ‘Legacy Solution Technique’ option from Solver>>Advanced panel in Chemkin. How can I activate this?
- >Advanced panel in Chemkin. How can I activate this?" target="_blank" rel="nofollow" title="LinkedIn">
- >Advanced panel in Chemkin. How can I activate this?" target="_blank" rel="nofollow" title="whatsapp">
- >Advanced panel in Chemkin. How can I activate this?" target="_blank" rel="nofollow" title="reddit">
- >Advanced panel in Chemkin. How can I activate this?" target="_blank" rel="nofollow" title="facebook">
Tagged: 18.1, chemkin, Chemkin Models, fluid-dynamics, Miscellaneous
June 5, 2023 at 7:06 am
FAQParticipantThe Legacy Solution Technique option will not be displayed until it is turned on from the Edit>Preferences menu. Once “Display Legacy Solver Options” is checked off under preferences, it will immediately become available from the Solver window (under Advanced tab).
- Skewness in ANSYS Meshing
