March 17, 2023 at 9:00 am
FAQParticipantIt is no longer necessary to add in the Additive Wizard or DED process extensions from the Manage Extensions Menu in R2022-R2. If you have an Additive Suite License, you should see all the AM Analysis Options from the WB Project Page, Toolbox Window, under ‘Custom Systems’ folder.
