I can not see ‘Mesh Method’ option in right click on Mesh or by right click after selecting body. I see Mesh Group Sizing Contact Sizing Inflation Mesh Edit Mesh Numbering Contact Mesh Group Contact Mesh Node Merge Group Node Merge Node Move Why does this happen?
March 17, 2023 at 8:58 am
FAQParticipantPlease make sure that Assembly Meshing option is set to None. Then you can have access to other meshing methods.
- Skewness in ANSYS Meshing
