Discovery Add-ins
Discovery Add-ins
I-Beam Lab in Ansys Discovery’s Extension Builder
    • SolutionSolution
      Participant
      Discovery Extension Builder: I-Beam Lab
      This is an Academic Use Case Implemented in Ansys Discovery’s Extension Builder which constitutes an educational tool complementing the theoretical/analytical learning of static analysis –specifically beam analysis – with simulation. This will help us understand the physical phenomena with visualization, such as the stress and strain distribution in a beam due to loading. You will learn how to use the Ansys Discovery’s extension builder capability to perform these analysis. You will find detail documentation which has step by step guidance to learn this I-Beam lab.
      This lab will help you build your own extension/add-in in Ansys Discovery. Also, you will get brief understanding of the model setup in Discovery to perform static structural analysis.
      ?THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OR SUPPORT OF ANY KIND, EXPRESS OR IMPLIED. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. FULL DETAILS OF THE TERMS OF USE OF THIS SOFTWARE CAN BE FOUND HERE.
