I am working with line bodies in Workbench Mechanical and the “Stiffness Behavior” can be either “Flexible” or “Stiff Beam”. What is the difference?
June 5, 2023 at 7:05 am
FAQParticipantThe “Stiff Beam” option approximates a rigid beam by making the Young’s modulus 1e4 times higher than the one defined in the Engineering Data Workspace. Additional information can be found in the documentation: ANSYS Documentation > Mechanical Applications > Mechanical User’s Guide > Specifying Geometry > Geometry Introduction > Stiffness Behavior > Stiff Beam
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
