I am using the Pre Inflation (Fliuent Meshing) option in ICEM and am encountering the following error as it launches: An Internal error has occurred: can’t read “mesh_OUT”: no such variable What does this mean and how can I get around it?
Tagged: 18.2, fluid-dynamics, General, icem-cfd, Tetra/Prism
June 5, 2023 at 7:06 am
FAQParticipantFluent meshing operates from a volume mesh and requires this as an input. The error is thrown because there is no input volume mesh for Fluent Meshing to operate on. If you generate the volume mesh, Pre Inflation will run normally.
- Skewness in ANSYS Meshing
