I am using the Fluent FGM combustion model in V 18.2 and have encountered a segmentation fault. My PDF file was generated with Fluent V 15.0. I can run my case in Fluent V 16.1, but when I load the same case in V 18.2 , the seg fault occurs. Is this a defect? How can I work around it
April 5, 2023 at 2:32 pm
FAQParticipantThere were a large number of changes to the flamelet and FGM tables between V 15.0 and V 18.x. One of the main ones were some changes to the structure of the PDF file to accommodate 5D table options. V 15.0 tables may there fore no longer be compatible with V 18.2 The workaround is to regenerate the PDF file in V 18.2 so that its structure becomes compatible with the release.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
