I am using the Fluent Battery Parameter Estimation tool to fit parameters to my experimental discharge curves, but all the parameters are being calculated as -1.#IND00e+00. What can be wrong?
May 15, 2023 at 8:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: battery, parameter, curve
1. 2053375.pdf
- Skewness in ANSYS Meshing
