I am using SpaceClaim, and when I try to do a Pull, Move, Combine or any feature on the Toolbar, the options that usually that overlay viewe window on the left fail to show up. How can I fix this?
March 17, 2023 at 8:58 am
FAQParticipantThis is a SpaceClaim Preferences Setting that can get corrupted in some older releases by using Dicsovery Live. To fix it, go to SpaceClaim Options from File. Under Popular> Control Options, toggle Tool guide position to the desired location (usually left). This should allow you to view the options again
- Skewness in ANSYS Meshing
