I am using Chemkin v19.0 to postprocess a large reaction mechanism. I am looking at the ROP analyzer reaction rates bar graph and comparing it with graphs of reaction rates plotted as functions of position. These do not appear to be consistent. Is this a defect? Which is the correct rate?
Tagged: 19, Analyze Results, chemkin, Chemkin UI, fluid-dynamics
June 5, 2023 at 7:06 am
FAQ
ParticipantThis is a defect that affected V 19.0 and prior releases for duplicate reactions. The values from the rate plots are correct. The bug was that the ROP analyzer was not summing contributions of duplicates reactions as it should have. This defect is addressed in Chemkin R 19.1
- Skewness in ANSYS Meshing
