March 17, 2023 at 8:58 am
FAQParticipantPlease ensure that in Fluent in File > Save Picture, the Format is set to PNG. Select PNG and click Apply. If the Format is set to JPG and the command: /display/save-picture test.png, is issued, Fluent will write a .jpg format image with a .png extension. As a result EnVe won’t be able to load this file.
- Skewness in ANSYS Meshing
