I am trying to use the Battery addon module for Fluent, but the Parameter Estimation Tool doesn’t appear to be working. I get the same result in v 17.2 and 18.2. All the parameters come up as -1.#IND00e+00.
Tagged: 19, fluent, fluid-dynamics, General, General - FLUENT, MHD/EHD
March 17, 2023 at 1:10 pm
SolutionParticipantThe parameters the module is fitting are 5th order polynomials. When a fit is not achieved, the mostly likely cause is that not enough voltage time data has been provided. While the minimum is 2 V-Time curves at different C rates, 5 curves are recommended. If there is an error in the data, such as a typo that has produced an outlier point, this may also prevent the fit from being successful. Please see the attached document for more information on the Parameter Estimation Tool
1. 2055232.pdf
- Skewness in ANSYS Meshing
