I am trying to model a second Mixture fraction stream as an inert. For some reason, when I try to activate the inert model, I find that it is greyed out/inactive. Why is this?
Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, materials, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantThe inert model was created to avoid having to solve an inert stream with a second Mixture Fraction (and its variance.) If you remove the second stream from the PDF, you will be able to activate the inert model to add a transport equation for the inert. In this situation, the PDF gets accessed with conditioned variables that account for the presence of the inert. It is a valid approach, since the inert is just a diluent, and saves you a transport equation.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
