I am simulating flow past an airfoil, and I want to evaluate how the drag and the lift are affected by the angle of attack. I was able to get results for 0, 2, 4 and 6 degree angle of attack. However, once I went to 8, 10 and 12 the model did not converge. I am wondering if I am doing something wrong?
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: angle of attack, airfoil, converge, transient
1. 2049274.pdf
- Skewness in ANSYS Meshing
