I am setting up a porous medium for which I want to use a power law resistance. How can I calculate the Co coefficient from my pressure drop data?
Tagged: 2019 R1, BCs & Interfaces, compressible-flow, fluent, fluid-dynamics, materials
January 25, 2023 at 7:16 am
FAQParticipantCo can be estimated from (dP/dx)/Velocity^(C1), This relationship is best determined from data that provides the pressure drop across your porous medium as a function of different velocities, as a single point is insufficient to determine the trend in dP with velocity. Plot dP/thickness vs. velocity to get an idea of the shape of the curve. The curve shape can be used to determine the velocity exponent, C1. Then, fit Co according to the magnitude of dP/dx.
- Skewness in ANSYS Meshing
