I am setting up a multicomponent case with diffusion with kinetic theory. How can I find the Lennard-Jones parameters for my species?
Tagged: 2022 R1, BCs & Interfaces, fluent, fluid-dynamics, General, materials, Species/Reactions
March 17, 2023 at 8:59 am
FAQParticipantThere are a few Chemkin databases that have these parameters for many species. If you have ANSYS Chemkin installed, you can find parameters in the file tran.dat in C:Program FilesANSYS Incv2xxreactiondata This file covers a large number of species, including radicals and ions.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
