I am running Nox Post-processing on a finished combustion solution in Fluent V 19.2. When I select the PDF mode to be Temperature/Species under the Turbulence Chemistry Interaction tab, and elect to use the transported variance equation, there is an instant SIGSEV error when the run is started. This used to work in V 17.2. What is the best workaround in current releases, and when will it be fixed?
Tagged: 2019 R1, combustion, fluent, fluid-dynamics, Pollutant Models, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThis combination of models (Temperature/Species PDF mode with transported variance) was not working in R 19.x. It is fixed in 2019R3. The current workaround for v 19.x and 2019R1 or new releases is to use either: (a) Use the temperature PDF mode or (b) Use the algebraic variance option if temperature/species PDF mode is selected
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
