I am running ICEM V 18.0 and, when I run Prism, it does not appear to run as before. Instead, something called the Python FieldMesher launches. Why is this?
Tagged: 18, fluid-dynamics, General, icem-cfd, Tetra/Prism
June 5, 2023 at 7:06 am
FAQParticipantThere is a defect in the ICEM V 18.0 release that cause Pre Inflation (Tgrid Prism library) to launch instead of the regular post -inflation (ICEM Prism). This defect was addressed at Release 18.1. Since ICEM releases are quite backward compatible, the recommendation is to upgrade to V 18.1
- Skewness in ANSYS Meshing
