I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
January 25, 2023 at 7:17 am
FAQParticipantYou can use the following macros to get echem reaction rate: —————– F_STORAGE_R(f, tf, SV_ECHEM_RX_0 + j): j is from 0 to rm->n_reactions F_STORAGE_R(f, tf, SV_PHI_1_FARADAIC_FLUX): total current density on an echem reaction wall —————– the unit of them is amps/m2.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
