I am running a simulation in parallel which features a moving mesh with a GGI interface. I noticed that the overlap nodes are very high for my parallel partitions and I can’t reduce this by changing to a different partitioning method. If I run the case without moving mesh, the number of overlap nodes are significantly reduced. Why does this occur?
Tagged: 18, BCs & Interfaces, cfx, fluid-dynamics, General - CFX, materials, Moving/Deforming Mesh
March 17, 2023 at 8:58 amFAQParticipant
If the mesh on either side of an interface is moving, then all nodes on that interface are marked as overlap. ‘Overlap’ simply means that a node (and it’s associated mesh faces) is a candidate for interface re-intersection. This is required since, with moving mesh, we never know a-priori where (or how) the mesh on each side of the interface will actually intersect; we must presume that point ‘A’ on one side of the interface could intersect with *any* point on the other side of the interface. Although the memory usage will be increased due to the high overlap, there shouldn’t be too large a hit in terms of the CPU time required for the solution.
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
