I am running a Forte simulation and it has been running for a long time without any output to the Monitors. How can I figure out what is wrong?
Tagged: 19, fluid-dynamics, Forte, Forte General, Other
June 5, 2023 at 7:06 am
FAQParticipantThe first diagnostic tool is to look at the Forte .log file in the Nominal directory for the run. This will usually tell you where the run is hung up. One common problem is for a run to fail during the initial meshing stages because the Material Point falls outside of the solution domain on the initial crank angle. Barring any other errors in the setup, shifting the Material Point to a better location usually allows the simulation to run and complete normally.
- Skewness in ANSYS Meshing
