I am running a CHT case and getting some strange temperature trends for an interface that connects solid object with sharp edges to the surrounding gas. What settings can I use in Fluent and CFX to address this?
January 25, 2023 at 7:16 am
FAQ
ParticipantIn CFX you can set the expert parameter ‘skew diffusion scheme=3’ In Fluent, the equivalent to the CFX parameter is to type (rpvar ‘temperature/secondary-gradient? #f) in the Fluent TUI. This setting drops all nonorthogonal diffusion contributions, which is less accurate (zero-order) for skewed cells, but more robust/bounded. An alternative workaround, which does something like this at just the boundaries/interface, is to type “solve set expert” in the TUI and to answer ‘yes’ to the first question (‘use alternate formulation for wall temperatures?’.) This second option might be better, as it affects only the interface connection.
- Defining heat transfer coefficient (HTC)
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Thermal Analysis of a Radiator Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- What is the difference between internal and external emissivity?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- How to use Thin Walls with Thermal boundary conditions?
- Where do I enter radiation properties such as emissivity/absorptivity, are there any recommended values for certain surfaces, and where do I find them?
