I am running a CHT case and getting some strange temperature trends for an interface that connects solid object with sharp edges to the surrounding gas. What settings can I use in Fluent and CFX to address this?
January 25, 2023 at 7:16 am
FAQParticipantIn CFX you can set the expert parameter ‘skew diffusion scheme=3’ In Fluent, the equivalent to the CFX parameter is to type (rpvar ‘temperature/secondary-gradient? #f) in the Fluent TUI. This setting drops all nonorthogonal diffusion contributions, which is less accurate (zero-order) for skewed cells, but more robust/bounded. An alternative workaround, which does something like this at just the boundaries/interface, is to type “solve set expert” in the TUI and to answer ‘yes’ to the first question (‘use alternate formulation for wall temperatures?’.) This second option might be better, as it affects only the interface connection.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
