I am running a Chemkin flamespeed calculation in Chemkin V 19. All the runs in my parametric sequence are failing with a runtime error as follows: Start running Flame_Speed (C1) for analysis run #2…… Possible runtime error encountered, retrying Finish running Flame_Speed (C1) for analysis run #2: failed Start running Flame_Speed (C1) for analysis run #3…… Possible runtime error encountered, retrying The module gets to ~179 grid points (~16 GB of RAM) and then issues the runtime error and restarts. My machine as 128 GB of RAM. How can I resolve this problem?
Tagged: 19, chemkin, Chemkin General, fluid-dynamics, Other
August 25, 2023 at 12:16 pm
SolutionParticipantPlease refer to attachment to access the solution. Keywords: mechanism, 32 bit, resolution, reduction
1. 2053374.pdf
- Skewness in ANSYS Meshing
