I am running a CFX case and restarting from a previous solution. The partitioner fails with the following error: Error detected by routine PSHDIR CDRNAM = /FLOW/MESH/LATEST/REG1 CRESLT = NONE Current Directory : /FLOW/CEL/CBCK_CALLS +——————————————————————–+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +——————————————————————–+ How can I resolve this?
Tagged: 2019 R1, cfx, fluid-dynamics, General, Modeling/Setup Advice, rotating-machinery
March 17, 2023 at 8:58 am
FAQParticipantThis error occurs when the starting .def file uses expressions to define boundary conditions, and these expressions are not present in the .res file. For instance, changing to a variable rotation rate for a rotating domain. If the new variable rotation rate is based on another expression that also did not exist in the.res file, this will produce a callback error beause the rotation rate is undefined. . The best practice is to ensure that the .def file and .res file expressions coincide, especially if there is interdependence. NOTE: This may involve adding the expressions to the setup that generated the restart .res file and setting them to an initial value that will proice a smooth restart. Then, run one timestep to populate the with the values of the expressions.
- Skewness in ANSYS Meshing
