Tagged: 3d, ANSYS SpaceClaim DirectModeler, body, fluid-dynamics, lock, Split
January 25, 2023 at 7:16 am
FAQ
ParticipantIf the body/component is locked then you can not select that body for splitting. Please remove lock for that body by selecting body/component then right click and select Lock. Once you unlock the body/component, you can select them to split.
- Skewness in ANSYS Meshing
