I am having some trouble post-processing Chemkin solutions in Excel. Excel won’t open, from inside Chemkin, and when I post-process the *.ckcsv file from outside Chemkin, there is an enormous amount of data. How can I gain control of the output from Chemkin, both in terms of getting Excel to open and controlling the amount of data that is generated?
Tagged: 19, Analyze Results, chemkin, Chemkin UI, fluid-dynamics
August 25, 2023 at 12:16 pm
SolutionParticipantUsually, problems in getting Excel to work with Chemkin come from a failure to configure Excel from within Chemkin. There are also several ways to streamline the post-processing data. Both of these are outlined in the attached resolution document
1. 2054113.pdf
- Skewness in ANSYS Meshing
