Tagged: 18.1, contact, mechanical, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantThis message indicates that the two nodes that define the spring connection are coincident. The length of the spring connection must be greater than 0.0 with a tolerance of 1e-8 mm. You can view the Reference and Mobile coordinates in the details of the spring to calculate the length of the element.
