I am getting ready to run my case, and notice that the Uncertainty option is grayed out. How can I get access to this option?
June 6, 2022 at 8:33 am
FAQParticipantUncertainty is measured according to changes in certain variables of interest, such as a reaction rate constant, or reactor inlet temperature. At least one such variable must be set up as a parameter before you can run an Uncertainty analysis.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
