August 25, 2023 at 12:16 pm
FAQParticipantThe mixed order mesh elements error occurs when you have following condition: 1. A shared multibody part containing solids and surface bodes, and 2. In Mesh settings, under Defaults options, Element Order is set as “Program Controlled” Under this condition, solids get meshed with higher order element while surfaces get meshed with lower order. This results in mixed order meshing which is not supported by Mechanical solver. To overcome this issue, simply change the Element Order option to “Quadratic” which will mesh all solid and surface bodies with higher order elements. Refer attached image which shows this option.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
