How to work with large tip gaps in Turbogrid and fix the error: Last blade profile is not defined as a shroud tip and is too far (x of span) from the shroud for reliable intersection. Must be at least 0.88 of span.
April 13, 2023 at 7:32 am
SolutionParticipantWhen defining blade geometries where the tip gap is very large, issues can occur where TurboGrid cannot generate the blade. The attached document shows a generic example of a blade with large tip clearance and the error TurboGrid generates, and the solution using Surface Extension Factor.
1. 2050448.pdf
- Skewness in ANSYS Meshing
