Tagged: 19.2, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 1:10 pm
SolutionParticipantIt is possible to use multiple cell registers for dynamic mesh adaption by using execute commands in-stead of the build-in dynamic adaption. The attached document describes an example to define these registers and execute the mesh adaption in a fixed interval. The description is valid until Fluent 19.2. For newer versions, refer to the documentation of expressions.
1. 2056932.pdf
2. 2056932.zip
- Skewness in ANSYS Meshing
